Please could someone build me a PC around these parts?
The Skylake build will perform better but Haswell still works fine.
The Super Flower PSU is high quality and plenty of power for an i5 / GTX 970.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor (£144.99 @ Ebuyer)
Motherboard: MSI H97 PC MATE ATX LGA1150 Motherboard (£65.58 @ Amazon UK)
Memory: Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600 Memory (£31.20 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£37.98 @ Novatech)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card (£274.98 @ Amazon UK)
Case: NZXT S340 (Black) ATX Mid Tower...
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor (£172.79 @ Novatech)
Motherboard: Asus H110M-A Micro ATX LGA1151 Motherboard (£49.99 @ Novatech)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2133 Memory (£39.48 @ Ebuyer)
Case: NZXT S340 (Black) ATX Mid Tower Case (£58.98 @ Amazon UK)
Power Supply: Super Flower Golden Green HX 550W 80+ Gold Certified ATX Power Supply (£63.48 @ Aria PC)
Total: £697.68
Generated by PCPartPicker 2016-02-27 10:53 GMT+0000
Will that Motherboard be any good? and also are you sure that that PSU will be able to handle everything at full load? I am more than happy not to go with skylake so if you could suggest a similar Haswell build then it would really help!
Total: £677.19
Generated by PCPartPicker 2016-02-27 11:40 GMT+0000
Just made a few adjustments to bring it closer to the budget. I changed the CPU to a 4590 as I read that that was the price-performance 'sweet spot' i5 and the Asrock board has better reviews. Thanks so much for your help and here is the buid I will be putting together within the next year, if you do see this, could you give me an idea on how it will run the newest games? I don't mind if you can't but I can't look up Youtube benchmarks atm as I'm on holiday and I only have a bit of mobile data left this month and YT uses loads! Thanks SO much again for all of your help!
http://uk.pcpartpicker.com/p/zwt87P
The H110 motherboard is fine. It just doesn't have a lot of features the more expensive boards have. It has less USB and SATA ports and only uses one video card and does not overclock. If you want more from the board you can move up to H170 but the cost goes up as well. The i5-6500 does not overclock so a Z170 board has no major benefit except for SLI. The Skylake build is the newest tech.
