Question Please Help! Experiencing stutters
Silver Shroud
7
Please help I'm experiencing stutters with my high-end pc in games like Cod Mw 2019 (campaign), The Forest, Subnautica.
My drivers are up to date, Windows 1909, OS build 18363.863, No Cracks. ( Important: I Changed from Amd to Intel during Christmas)
CPU: Intel i5-9600k @5.15ghz (overclock or no overclock still results in stutters)
Motherboard: Asus Prime Z390-A
PSU: Evga 750watt gold+ efficiency
Ram: Corsair Vengeance Rgb Pro 16gb (2x8gb) @3200mhz
GPU: Evga Rtx 2070 Ultra
Storage
SSD:
Samsung Evo 860 1tb
HDD: Western Digital 1tb
Here's a Link to me playing Cod Mw 2019's campaign with stutters
View: https://www.youtube.com/watch?v=V2on1YKHmOQ
I believe my Cpu is the cause of my stuttering but at the same time I don't understand as others don't getting stuttering with the same cpu sometimes
Assuming this isnt a thermal issue.
Did you do a Windows reinstall when you switched from AMD to Intel? Or did you move your system drive over?
If you moved the drive from your old system you need to start with a reinstall of Windows.
I installed the ssd after upgrading then set it as my boot drive so a fresh install of windows
I don't have anything too important on here so could just wipe my ssd and try to reinstall windows and check if it fixes it (also could it be because of the amount of space left in the ssd 138gb?)
