Please help finding compatible ram for my Samsung Laptop
mudassar788
13
Hello,
I have Samsung Ativ Book 8, model number is NP780Z5E-S01UB.
It came with 4gb on board & 2gb changeable ram (total 6gb). However, 6gb is quite low for me. I am thinking to replace 2gb stick with 8gb. Here is the screenshot of ram which is previously installed in my laptop.
http://i.imgur.com/E1PHO85.jpg
One of my online friend suggested me G.Skill ram (link below) & he told me that it will work perfect with my laptop, but I am bit confused as my existing ram is PC3-10600S while recommended one is PC3L-12800
(Currently out of stock, but I find similar on different vendors)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231704&cm_re=gskill_laptop_rams-_-20-231-704-_-Product
Now, can anyone please suggest me some proper compatible ram with my laptop? I am bit worried because I will not be able to return once received.
Waiting for some suggestions.
Thanks
Thanks bro, Crucial is recommending
DDR3 PC3-12800 • CL=11 • Unbuffered • NON-ECC • DDR3-1600 • 1.35V • 1024Meg x 64
DDR3 PC3-14900 • 10-10-10-30 • Unbuffered • NON-ECC • DDR3-1866 • 1.35V • 1024Meg x 64
So, it means that any ram will work with my laptop, 10600S or 12800 or 14900?
