Please Help! HD making squealing sounds. Won't boot!
ls1
51
Hey everyone, I have encountered a weird problem here and I'm kind of out of ideas, very worried!
I built this computer back in 2006/2007, have upgraded most parts since, but the Motherboard, PSU and HD are all original. Never had any problems. Well, last week my computer crashed, and when I tried to start it back up, the HD started making a weird beep/squeal sound every few seconds (like the sound of a low pitched beep and squeal combined). It wouldn't boot. Each time the computer would say that it detected a HD issue and could not communicate with the HD. In BIOS I could see the HD was still recognized just fine. I tried other SATA ports and cables... nothing. Tried removing the CMOS battery and pressing the reset buttons.... nothing!
So I assumed there was a problem with the HD heads, which I figured made sense, considering the HD is like 8 years old. So I tried putting it in the freezer for a few hours, and then popping it back into my comp. It started right back up, no sounds! I quickly got all my files off the drive. About 24 hours later it started to make the sounds again, and crashed. Back to that problem again. I tried freezing once more.. it worked again, but only lasted for 30 mins this time. So, I ordered another HD.. same brand/model, just a little larger capacity.
That new HD came in today, I hooked it up, popped my Windows 7 installation disk in there and it started right up, no problems, no sounds. I figured, "good, must have been that harddrive for sure." So I installed Windows, started instaling drivers, and maybe 2 hours later while windows updates were installing, I start to hear that same SOUND again, same as the old HD!!! Of course, it froze up, and crashed. I tried restarting again and I'm getting the SAME EXACT problem from the old HD!
Now, this makes me think it never was the HD to begin with! I mean, there is the chance that this one had problems from the factory and I could try RMAing it and trying another... but doesn't it sound it that's a slim chance?
Currently my mobo is displaying code 75 (USB?). It's worth mentioning that when I try (and fail) to boot, the numbers on there fluctuate a bunch, then once Windows is about to bring me to the login screen, a blue screen flashes for a millisecond and it restarts.. that beep/squeal sound happening with no real sound pattern the whole time. Sometimes, when I go into BIOS, theres some weird string of numbers that are written in jibberish (like symbols and stuff) strawn across a random part of the screen, and those numbers are flucutating....
Also worht mentioning, this mobo has the original CMOS battery in it (2032 coin shaped battery), do you think that might be the problem? Should I try replacing that??
Any ideas you guys might have, please let me know, thanks!
Specs:
Abit IP35P Motherboard
Intel Q6600
EVGA GTX 750ti ftw
PC Power & Cooling Silencer 610w
4GB RAM
Windows 7 64bit
Seagate Barracuda 7200 RPM 250GB (OLD HD)
Seagate Barracuda 7200 RPM 500GB (NEW HD)
This same thing was happening with an external drive I had once. It turned out to be the cable. Suppose it's worth a shot, before you spend the $$$ on the mobo and power supply. Should be able to get a new SATA cable from bestbuy, radio shack, a place like that for $5 or less.
Sorry this is still happening man. I definitely feel for ya...
