Question Please help im lost!!!
Jun 12, 2023
5
I have a ibuypower system with a amd ryzen 9 7900x on a asrock b650m-c with a pny geforce 4070ti, 64gb ram and 2tb so far but upon start up games will startup at 180fps and then when game play starts it drops to under ten. Any ideas so far we have tried;
Settings in;
Games
Windows
Nvidia
Bios
And flashed new bios to latest
Updated all drivers
Had multiple people walking me through different things to help and nothing I'm pulling what little hair I have left out!!! PLEASE BALD WONT LOOK GOOD ON ME!!!!
Crazy thing is the display is going through graphics card. The fans run on start up and then it's lights are on but not utilization past that for frame rate or anything.
what is the PSU make, model and wattage?
(why does that remind me of ICQ from back in the late 90's?)
I'm just look at your hardware combo 170w cpu and that motherboard etc
Pre-built and boutique builders like ibuypower usually cheap out on the PSU and motherboards to cut down costs. I would consider changing the current PSU with some higher quality, assuming your unit is bad.
To be honest that a really nice CPU and the motherboard not so nice but if it says it supports that CPU then I'm not 100% sure atm
I did cringe a bit when I saw the brand ibuypower? yeah ya might have power but did they supply the quality?
Once I have eaten I will try and figure it out but I can only try can't promise anything that is unless you get help before then lol
The motherboard should be ok, just seems if a ryzen 9 7900x over kill for it .
anyway need to know full spec of the PSU
It might just be as simple as the card is bad. I would send the system back with an explanation of what is wrong and let iBuyPower deal with it.
hahah i been posting to the wrong reply lol oh well never mind.
I have come to the conclusion without knowing what the PSU it's a good possibility.
Are you using an UPS?
Is you mains supply good
has the build of the the PC been done correctly and to a good standard.
Reactions: Avro Arrow
One thing is certain, the OP paid a very pretty penny for this build and so they may as well use the one advantage of paying the extra money to a pre-builder... being able to send it back if there's an issue.
yeah I agree pre build and problems send it back and don't mess around with to much, I just prefer to build my own I know it's done correctly.
It's just MY personal preference after building My own home PC's for a long time.
But I am not saying these pre built PC are not well built and professionally.
I was going to ask that but if it's just shutting down at desktop it could be
Power supply
It's connected to an a circuit breaker that cant take the sudden loads
The mains electric supply is not stable
It's connected to an UPS that trips because it cant handle the draw.
Kernel Issue
Driver Issue
Ram Issue
I do not see OP talk about shut downs only a drastic FPS drop!
