Hello - I am planning to build up a small computer so I can play some games and do work. It might, in the future, be used to record TV and output to a TV (kind of HTPC-like). I'm looking at the motherboards on Newegg to see what's there. I'll be putting in a video card in there, but I'm not looking for ultra-performance and overclocking all over the place, so I'm fine with default values and on a somewhat budget. I think I'll be putting in a Wolfdale CPU in there. I was looking initially at ASUS boards (something else not ASUS is fine, though) - there is 1) http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299 and 2) http://www.newegg.com/Product/Product.aspx?Item=N82E16813131041 with a $50 price difference. The only significant differences I see (that might matter to me in the future) are the increased number of PCIe slots. Is it not necessary for me to get the more expensive boards?
Thanks,
- Eli
Thanks,
- Eli
