Please Help me. Debug code 71 and screen doesn't turn on!!! please help!
TechiGamer
372
Hi !
Today I wanted to try out overclocking my i5-4670k on my msi gaming 5 motherboard. I went into my bios and loaded optimized defaults and then I set the cpu core voltage to 1.2V and my cpu ratio ( I think that is what it was called ) to 46, so 4600 mhz or 4.6 ghz. I have a very good cooling system and my cpu temperature before I loaded those settings was 8 celsius. Now I can't boot up. I am getting number 71 on my debug led indicator. I tried unplugging the battery to reset the bios, I also tried connecting my dvi cable to the motherboard just to see if that is outputting the video. What can I do??? When I boot up there is nothing on my screen!!!!! Please help me. This is the first time I have ever overclocked and those are the only 2 options I altered in the bios!! And yes I have the latest bios.
The debug indicator is solid 71!
Please please help me! Thank you :)
TechiGamer
372
HI!
As posted above, my motherboard is a z97 gaming 5 from MSI. I'm not sure what you mean about drive config. I have an r9 280x crossfre setup if that is what you are referring to...
TechiGamer
372
Update*
I unplugged everything in my system and started testing with the motherboard and processor alone. Then I slowly added and plugged in more and more devices until I finally discovered that one of my RAM modules is not working. That was causing this whole issue :)
So now my system is working great! Cheers :)
Similar threads
