[SOLVED] Please help me, dram frequency shows 1066 for trident z neo 3200mhz.
Sep 5, 2020
I have purchased 2 new ram stick, 3200mhz Tridentz Neo (8GBx2). I did overclock my motherboard and I am still stuck at 1066mhz. I tried every possible thing and still having difficulty.
I have a MSI B450M pro vdh2 motherboard with Ryzen5 1600.
Please help me.
What do you mean by overclocking your motherboard?
Seems like your memory is running at stock speeds DDR-2133 or 1066 MHz.
Have you updated your motherboard to the latest BIOS?
Did you enable the XMP profile in your BIOS?
Also,assuming that you have the R5 1600 1st gen not the AF(which is 2nd gen) you might run into instability when trying to run at 3200... if that happens, lowering the speed to 3000, 2933 or even 2800 might help.
