Please Help Me finding the perfect motherboard for my first custom PC build!
Ashish_Avik
Commendable
May 18, 2016
4
Hi Guys,
i am making my first custom low budget PC
here are the spec, please find me the perfect motherboard for this or tell me that my chosen motherboard is correct on not, if possible then please find me a black motherboard so that it can match with my case.
SPECIFICATIONS
Processor: AMD FX 6-Core Black Edition FX-6300 3.5GHz (Link)
Memory: Kingston FURY Memory - 8GB Module - DDR3 1866MHz CL10 DIMM (Link)
Note: I will be using two rams
SSD: Kingston UV300 240GB 2.5-inch Solid State Drive (Link)
Graphic Card
Note: Please tell me which one should i choose from the followings (all are 750 ti)
1.) ZOTAC GeForce GTX 750 Ti 2GB Graphics Card (Link)
2.) EVGA GTX 750Ti (Link)
3.) MSI N750Ti TF 2GD5/OC (Link)
4.)MSI GTX 750 TI 2GB DDR5 OC Edition Dual Fan Graphic Card (Link)
These are two motherboards that i had chosen please tell me is it right for my build or should i choose another:-
1.) Asus AMD M5A97 R2.0 Motherboard (Link)
2.) Asus AMD M5A97 LE R2.0 Motherboard (Link)
Last Up if u wanna see which PC Case i will using then here is it
Case: DEEPCOOL DUKASE V2 Mid Tower CASE W/ USB 3.0, Side Window (Link)
Thank for answering, all answers or question are appreciated... Thanks
If u wanna make this rig only for gaming purpose, go with the FX-6300 otherwise go for Intel i3 or i5 processors according to ur budget. go for Zotac version...its cool... next in case of motherboard go for M5A97 LE R2.0 version..its better
and hell no to DDR3 rams...its 2016 go for DDR4 rams with 2400Mhz go for corsair products ..they are best for gaming purposes...Good Luck to Your PC
thanku so much, everyone is saying to go with ddr4 so ASUS M5A97 doesn't support DDR4 memory kit thank u so much
lastly i am going to make this build for gaming as well as 1080p video editing and for web developmet
my total budget is $500 about 40,000 Indian RS
i am making this pc for gaming as well as video editing and web development
i would like to see your build , feel free to share plz
thank u so much, i will be using this motherboard and i am making this rig for gaming as well as video editing so which processor should i go for intel or amd. i have a question with motherboard, will i support two graphic cards
Cooler Master Chassis CMP 250: Rs. 2,600
http://www.snapdeal.com/product/cooler-master-chassis-cmp-250/1427945#bcrumbLabelId:2692
Intel i3 4130: Rs. 8,599
http://www.amazon.in/Intel-core-4130-3-4GHz-Processor/dp/B00EUUKVXM
Gigabyte H81M-S1: Rs. 3,620
http://www.amazon.in/gp/product/B00F4H9BH2/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=733112647&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B00EUUKVXM&pf_rd_m=A1VBAL9TL5WCBF&pf_rd_r=0JZ985YV20KQS5X3RWG4
G.Skill RipjawsX DDR3 8 GB (2 x 4 GB): Rs. 4,050
http://www.flipkart.com/g-skill-ripjawsx-ddr3-8-gb-2-x-4-gb-pc-dram-f3-12800cl9d-8gbxl/p/itmd2rysqgrmywpa
Zotac GTX 750Ti 2GB GDDR5: Rs. 9,775
http://www.amazon.in/ZOTAC-GeForce-Graphics-Black-Orange/dp/B00IFZ547Q?ie=UTF8&colid=16NJOXJBRF70U&coliid=I1GVQGJZBLU234&ref_=wl_it_dp_o_pd_nS_ttl
LG GH24NSC0 DVD Burner: Rs. 999
http://www.flipkart.com/lg-gh24nsc0-dvd-burner-internal-optical-drive/p/itmds9ftbrnayxwh?pid=IODDGAPZHBWHJWNR&otracker=from-search&srno=t_1&query=lg+dvd+writer&ref=276fc74b-4ba1-4cc3-ac74-94a925c087f9
Kingston UV300 120GB SSD: Rs. 2,760
http://www.amazon.in/Kingston-UV300-120GB-2-5-inch-Solid/dp/B017Y375L2/ref=sr_1_4?s=computers&ie=UTF8&qid=1463657857&sr=1-4&keywords=ssd+120gb
Seagate Barracuda 1 TB: Rs. Rs. 3,999
http://www.flipkart.com/seagate-barracuda-1-tb-desktop-internal-hard-drive-st1000dm003/p/itmd6uyn8vr4hrma?pid=IHDD6UYN8VR4HRMA&srno=b_1&ref=6ce1123c-a813-4ab8-8f84-5070ee9fd6d8
Antec VP450P: Rs. 2,925
http://www.snapdeal.com/product/antec-vp450p-smps/1251897?utm_source=earth_feed&utm_campaign=TopSubcategoriesPLA&utm_medium=cpc&utm_content=1251897&utm_term=,&campaignid=337147405&adgroupid=28081464325&adposition=1o1&network=g&device=c&targetid=pla-178299439765
Grand total: Rs. 39,327
If you can, stretch your budget and get an i5 4440.
