Please help me fix my drone
justindjohnson666
Ok so i have a sky viper 1700 well kinda the recever is and well after that is frankindrone but when i turn left or right it makes my drone do well just weird things it does fly just not like it should. Please help
Check the Mode that you are using.
Many drones have the option to be Mode 1 or Mode 2.
The transmitter controls do different things depending on the Mode.
Sometimes if you are not careful, you can accidentally change the mode. And control goes all astray. 🙂
Google "drones Mode 1 Mode 2"
Take a close look at the User Guide/Manual for your Sky Viper. And the transmitter settings.
Another thing to take a look at is the configuration: Could be "+" or "x".
Update: do not ignore the fine tuning (trim) controls. They can be very sensitive and it does not take much of a change to make the drone want to go all "frankiendrone" on you.
