Hi guys and girls, ive done a lot of reading and research on THG and through out the TGH fourms, and across the internet looking for what i want in a PC, I have aproximatly $1600USD including shipping and tax to New Zealand (so about 1-200 for shipping etc). The PC will be used for a mix of everything from Games to Aplications (WORD WinRAR) Photoshop to DvD encoding/ripping. I already have a 22" Dell widescreen and the OS
Ive priced the parts up at a local shop and at neweggg.com which is shown below, and from newegg.com it does work out cheaper, but i would also have to figgure in tax and shipping from the states
most of the specs are up for a lil tweeking
Any comments/help on this setup would be much apreciated
GIGABYTE GZ-X1 BLACK 0.6mm SECC / ABS Front Panel ATX Mid Tower Computer Case 350W Power Supply - Retail
Item #: N82E16811233009
$69.99
Item #: N82E16817153051
$109.99
Item #: N82E16813131182
$219.99
Item #: N82E16819115017
$299.99
ZALMAN 9700 LED 110mm 2 Ball CPU Cooler - Retail
Item #: N82E16835118019
$59.99
Item #: N82E16820231098
$88.99
Item #: N82E16814150173
$309.99
Item #: N82E16822136053
$89.99
Item #: N82E16827106073
$35.99
Item #: N82E16823109156
$21.99
Grand Total: $1,306.90
Cheers
Jase
$69.99
Thermaltake Purepower RX W0143RU ATX12V / EPS12V 550W Power Supply - RetailSomething simple but functional with good cooling
$109.99
ASUS P5K DELUXE/WIFI-AP LGA 775 Intel P35 ATX Intel Motherboard - RetailIs this enough?
$219.99
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - RetailI would like a Motherboard with WIFI to save buying a wireless PCI card
$299.99
$59.99
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ - RetailWill this go alright with the CPU on a mild overclock, and will it work alright in the case?
$88.99
XFX PVT80GGHD4 GeForce 8800GTS 320MB GDDR3 PCI Express x16 HDCP Video Card - Retail2GB minimum
$309.99
Western Digital Caviar RE WD3200YS 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEMHas to be an 8800 series card, would like a GTX but i dont think the budget will stretch that far
$89.99
LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-05 - OEM320GB minimum
$35.99
Microsoft Comfort Curve 2000 B2L-00047 Black USB Ergonomics Keyboard Mouse Included - OEMJust needs to be a fast DVD burner
$21.99
Cheers
Jase
