Please help me
Rico Kleynhans
11
Please help, PC restarts while playing games... I putt in a new mobo. so it cant be that.. I did download occt and ran a test for an hour no issues at all on psu, also ran becnhmark on gtx680 no issues.. also running speccy and no over heating issues either. temp is running at 30 to 40 on everything..
Sometimes it doesnt restart at all and sometimes it restarts 5 times in a row.
PC Specs: i5 (2500) 2nd Gen 3.30ghz
Gtx 680 Nvidia
OS:windows 8.1
4gig ram atm because one ram just popped before typing this.
are u getting blue screen error while the restarts or 3 beeps from he system ???if not then the ram should be fine 4 gb ram is not that bad its a little low for current games 6 gb is recommended for modern games and 8 gb ram is a good choice....less ram doesn't makes a pc restart while gaming if you are running out of ram the game will be laggy and the pc will get slow....
i think its the psu .......BTW what is the PSU you have not mentioned it...gtx 680 requires 38 amps @12+ volt rail and a minimum of 550 watt of psu ....
Hi, the PSU is a huntkey 700w so ye, pc was running fine for about an hour then as soon as i went into csgo insta restart... i want to stab my pc right now, also im not getting any bsod or beeps its a solid restart no error code...
Operating System
Windows 8.1 Pro 64-bit
CPU
Intel Core i5 2500 @ 3.30GHz 31 °C
Sandy Bridge 32nm Technology
RAM
4,00GB Single-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
Gigabyte Technology Co., Ltd. B75M-D3V (Intel Core i5-2500 CPU @ 3.30GHz) 28 °C
Graphics
E2341 (1920x1080@60Hz)
2047MB NVIDIA GeForce GTX 680 (MSI) 27 °C
Storage
1863GB Seagate ST2000DL003-9VT166 ATA Device (SATA) 24 °C
Optical Drives
TSSTcorp CDDVDW SH-222AB ATA Device
Audio
NVIDIA High Definition Audio
These are the temps my stuff is running at
and this is the error code from the event logs:
Event 41- Kernel Power
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
and i downloaded bluescreenviewer but nothing shows up in bluescreenviewer
This is a fresh install of windows 8.1 i installed windows about week and a half ago... drivers up to date for card and everything... I see a lot of people having this problem they bought new motherboards and still had problem new hard drive and same problem psu and that fixed it for some of them and for some i did not.. i also get the kernel error : kernel power event 55
