Sometimes my memory usage % goes up to 90 % and even though I exit all programs it still shows high memory usage. The only way to lower it is to restart the pc. Is there something wrong?
You can use the Media Creation tool to create a bootable USB flash drive to use to install Windows. As long as you install the same version that you already have, it will automatically activate.
Please do a memory test. Press Win+R to open Run, type in CMD, press Enter. Command Prompt opens. Type in mdsched.exe. It will ask for permission, tell it to restart and perform memory diagnostics.
At this point, I would recommend doing a fresh install of Windows. I would also recommend creating new install media to eliminate the possibility that your install media is corrupt.
Is there any other method rather than reinstalling windows completely? It just takes alot of time and I have tons of folders games etc..
You can try a method that disables startup objects within the scheduled tasks during Windows startup...
Please download Piriform CClearner Free, uncheck any install options that you don't want, and navigate to the Startup tab on the left. Take several screenshots, one of all the contents in each tab across the top (Windows, Scheduled Tasks, Context Menu, etc). If there are two many listings to fit them all on screen at once, take multiple screenshots. The more information I have on this issue, the better I can help you.
