Question Please help my decide
Aug 25, 2020
8
Dear HardwareGods!
I am an really indecisive person, and that is why i need your help! 🙏
So, i have watched hours of PC builds and now I am even more disoriented in what I should get...
So, these are my two system configurations of choice:
1.)
PCPartPicker Part List
CPU | AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor | $429.00 @ Amazon
CPU Cooler | be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler | $85.76 @ Amazon
Motherboard | Gigabyte B550 AORUS PRO AC ATX AM4 Motherboard | $189.99 @ Amazon
Memory | G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory | $168.98 @ Newegg
Storage | Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive | $189.99 @ Adorama
Video Card | MSI GeForce RTX 2080 SUPER 8 GB GAMING X TRIO Video Card | $730.00
Case | Fractal Design Meshify S2 ATX Mid Tower Case | $158.99 @ B&H
Power Supply | be quiet! Straight Power 11 750 W 80+ Gold Certified Fully Modular ATX Power Supply | $130.00
Case Fan | Corsair 43.25 CFM 120 mm Fans 3-Pack | $129.99 @ Best Buy]
TOTAL: $2212.70
2.)
CPU | AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor | $289.99 @ Amazon
CPU Cooler | Lian Li GALAHAD AIO 360 RGB 69.17 CFM Liquid CPU Cooler | $150.00
Motherboard | Asus PRIME X570-PRO ATX AM4 Motherboard | $243.99 @ B&H
Memory | Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3200 CL16 Memory | $177.99 @ Amazon
Storage | Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive | $169.99 @ Newegg
Video Card | Gigabyte GeForce RTX 2070 SUPER 8 GB Gaming OC 3X Video Card | $539.99 @ Newegg
Case | Lian Li PC-O11 Dynamic ATX Full Tower Case | $139.99 @ Adorama
Power Supply | EVGA G5 750 W 80+ Gold Certified Fully Modular ATX Power Supply | $145.98 @ Newegg
Case Fan | Corsair 63 CFM 120 mm Fans 3-Pack | $180.00 ]
TOTAL: $2037.92
should i spend that little bit more on performance??
or should i go for the optics and choose the 2nd pc???
I am thanking you in advance for any recommendations depending choosing or configuring something differently or help that you can provide.
ok so the case comes with 3 fans.1 at the back and 2 at the front.The case supports up to 9 fans,and if i were you i would fill all those 9 places with fans,but if u cant buy 6 fans and only 3,i would put 2 new fans at the front (top and middle possition),1 new fan at the rear and 3 coolers that come with the case up top.If you want to populate all 9 of those fan spots,just buy another 3 fan kit that i put in your build that i edited.
Reactions: KoiKarpf
Sounds like a plan, thank you very much!
Reactions: Dj0gany
