Please help! Need Quiet CPU cooler for Intel Pentium 4 (478)
PeaceLoving
94
Need some suggestions on a quiet fan for my Pentium 4 2.8 (478 chipset). The mobo i'm currently using is an ASRock P4i65G. Eventhough I'm planning to get a new set next year, I'd still like to keep this oldie for downloads.
I run BitComet at night and the CPU fan noise is really irritating. VERY LOUD!! I have already changed my other 80mm case fans and all are now running quietly.
Please! Suggestions! (AIRCOOL)
Thanks!
I just got this one for my socket 478 mobo and it's pretty good. Cooler Master Vortex TX / Socket A/754/939/775/370 / Full Copper / CPU Cooling Fan. It's not silent but it's a lot quieter than most. It also does a really good job of cooling since it's all copper.
I just looked at Newegg and here's the closest I could find:http://www.newegg.com/Product/Product.asp?Item=N82E16835103424
It looks like the newer model. Not a bad price either.
Best thing to do is go to Newegg or some other site and check the reviews of socket 478 coolers. A lot of review say whether or not the cooler is loud and how well it cools. This way you can compare prices against other coolers that interest you.
I suggest looking at Zalman they are known for silent fans that perform very well Most of their fans have a silent mode option
Check out the cnps7700 or the cnps7000 (smaller and less expensive verion of 7700)
I put the cnps7700 copper with arctic silver5 grease and my amd64 3200 dropped from 40'c at idle to now 33'c idle at 1800 rpm
But i tested it at 1000rpm idle and it's still at a cool 36'c and it's very silent
Also the design of the fan cools down all your other hardware
motherboard a8n-sli dropped from 35-36'c idle to 34-35'c
video card 7900gs dropped from 51'c idle to 47'c !!!
i can't tell my ram temperatures but it's right beside so i'm sure that its cooler also
Very good fan highly recommend it
Thank you both for your suggestions. I decided to go with the Zalman CNPS 9500. The 80mm fan is a little high-pitched for my taste though. 🙁
ps. When i was at the shop, it was very silent(ambient room noise was louder i suppose), but at night when everything is supposed to be quiet.....it irritates me a little. No problem though. Kinda getting used to it.
Thanks again.
