Hey guys, I've posted many times on this but still haven't obtained the answer. I'd just finished building my new PC and plugged it into the monitor, I powered it on and immediately noticed the monitor displayed "No Signal" so I thought I was on the wrong input on the monitor but I was wrong, it was on the correct input (VGA). So I checked the cable to make sure it was in and as usual it was. I then began to question if it was a problem with one of my components, my pc turned on (fans, leds) when I pressed the power so I knew it wasn't the PSU. I switched all my RAM sticks and used one just to be safe, no difference, same problem again "No signal". I took out the CPU and placed it back in making sure it was secure. So I now believe my Motherboard maybe faulty, I connected a internal speaker which came with my case, and whenever I turned the PC on the speaker gave me 2 clicks then a 5 second break and then it would repeat again I also noticed at that point the CPU and PSU fan would spin for 2 seconds every 5 seconds, which I found weird. Is it normal for the internal speaker to click, or does that mean a mobo problem. The question is did I get a DOA mobo, or is it another component? Thank you!
My System Specs: http://uk.pcpartpicker.com/p/mJrbdC
