I have built a new system and can't seem to get a stable OC 🙁. It's effecting both my part time business on the side and my schooling. Already spent countless hours researching and trying, but still can't get it stable. Have run many Prime95 tests, but they ALL end up on a BSOD (several posted bellow). Doesn't seem to be an issue with temps reaching too high. I hope the following will provide you enough information for some insight on what steps may be taken to solve this problem.
WOULD APPRECIATE ANY HELP, AND AGAIN THANK YOU SO MUCH IN ADVANCE! I am desperate 🙁....
CPU: AMD PHENOM II X6 BLACK EDITION 1100T Thuban
MOBO: GIGABYTE 880GA-UD3H
RAM: Kingston HyperX 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K4/16GX
GPU: Sapphire Radeon HD 6950 Dirt 3 Edition (have dual BIOS switch. One that's unlocked to 6970 shaders, and one at stock shaders. Currently have an OC using Sapphire Trixxx to match the 6970 memory/ gpu clocks *see pic below*)
SSD: OCZ Vertex Plus SATA II 120 GB HD (Holding OS + Games + Drivers ONLY)
HDD:
1x Raptor 7200 RPM HDD 500GB (Holding every other app minus games/ OS)
1x WD 2 TB Green HDD (used for backup/ video/ photoshop work)
OS: Windows 7 64-bit Ultimate
CPU INFO:
GPU OC *Notice the voltage is pretty high for a low OC, but wanted to make sure it's stable. I have tried all range of voltages to make sure*:
***ON TOP OF THE BSOD IMAGES I HAVE BELOW, I HAVE ALSO GOTTEN THE FOLLOWING ERRORS:******
STOP: 0x000000D1
STOP: 0x000000A1
STOP: 0x000000E1
HDD:
CPU INFO:
STOP: 0x000000D1
STOP: 0x000000A1
STOP: 0x000000E1
