Well in a sense no.
But the auto overclock and turbo core boost does not give you the maximum overclock you can achieve with a FX 6300 Amd cpu.
To keep the core at a fixed speed in your bios.
Turn off cool and quiet, and turbo mode.
If you manually set the multiplier in the bios, providing you have a decent motherboard.
And an aftermarket cpu cooler, and not the stock cooler that comes with the AMD FX cpu.
You can get a FX 6300 cpu to clock slightly higher than 4.1 Ghz.
Typically an FX cpu will from its default stock speed overclock about 800Mhz on average
So you could get it to 4.4Ghz and extra 300Mhz.
200 x 22 = a cpu core speed of 4.4Ghz.
At the moment your settings should be at 3.5Ghz 200 x 17.5 on the multiplier clock of the cpu in the bios.
If you want to try to manually increase the speed of the cpu, you may also have to add a bit of voltage to the cpu core when setting the multiplier value higher.
About 0.250Mv or 0.500Mv.
Do not go above 1.6v for the cpu core 1.45v is pretty safe but the cpu temp will rise that is why you need a good aftermarket cooler and not the stock Amd cooler that came with the cpu if you are currently using it.
If you want to try then I suggest that you up the multiplier value up in half multiple steps. example
For a fixed speed of 4.1Ghz you want 200 x 20.5 on the multiplier.
