Welcome to the forums
FYI one post will do, copy posts are merged.
"No POST", "system won't boot", and "no video output" troubleshooting checklist This checklist is a compilation of troubleshooting ideas from many forum members. It's very important to actually perform every step in the checklist if you want to effectively troubleshoot your problem. 1.Did you...
forums.tomshardware.com
this is the no boot troubleshooter, go down the list every step, at step 17, how many beeps you getting? do you have the speaker connected to the front panel header as described in step 17?
if you need a speaker for diagnostics and are feeling creative you can make one for testing
canned diagnostic speaker rant: speaker making 101
The diagnostic speaker is the motherboards main diagnostic feedback device.
the motherboard may be telling you where the problem is.
my speakers have this plug
http://images.crutchfieldonline.com/graphics/infolib/homelib/hSpeakerSpringClip.jpg
I use lamp wire but any stranded wire will do. literally any stranded wires. strip one end like so
http://www.antiquelampco.com/Shades/CordColors.jpg
attach the stripped end into the speaker spring clips on the speaker.
the other end of the wire should be trimmed like so the semi strip
https://wesbellwireandcable.com/images/cutwire.png
by doing a semi strip the wire case is now the socket.
plug one wire to the first pin, and the second onto the fourth pin.
power on the system and listen for beeps
end canned rant
and now a word on grounding, always ground yourself before and during working inside a computer.
Canned Grounding Rant-
shut down system and remove side panel. with the power cable plugged into the PSU touch a bare unpainted metal area of the case. (my favorite spot is an unpainted screw securing the PSU) once you have grounded yourself you can unplug the computers power cable from the PSU and can touch the system.
if you move your feet, or shuffle in your chair, plug in the cord, reground yourself and unplug again.
end canned rant-
