[SOLVED] Please Help Phanteks 400A Drgb or MASTERBOX MB520 Argb
Phanteks I'd say has better airflow because of the completely mesh front panel, and also a better designed built in argb controller.
It needs a 120mm rear exhaust fan adding.
That said the coolermaster is still absolutely solid and comes with an exhaust fan preinstalled.
There really isn't a lot to choose from them, buy the one that appeals to you more aesthetically.
Theyre both very good cases.
the phanteks also comes with pre installed fans but if am not wrong the coolmasters allows water cooling as the phanteks doesn’t?
Both allow water cooling.
The coolermaster as a front intake or top exhaust, the phanteks just as a front intake.
The coolermaster comes with 3 intakes and a rear exhaust preinstalled. The phanteks just comes with front intakes.
should i go with the phanteks maybe and add an rear exhaust fan?
