Solution Shadow703793 Mar 26, 2010 sorry man. i live in US only 4 years. why i need to short green and black wire? Click to expand... No problem. To start your PSU with out a motherboard, you will need to short the green to black. http://www.virtual-hideout.net/guides/atx_psu_mods/index.shtml This lets you test the loop with out powering up the board and if there is a leak, it's less likely to kill everything. MAKE SURE the PSU will not be in the way in case of a leak.
matvey Distinguished Dec 18, 2009 252 0 18,780 Apr 11, 2010 #51 Shadow703793 : Well done. Also, use Small FFT not Large FFT. i did all of them, all stable. thank you man. trick with the power supply was VERY helpful. Upvote 0 Downvote
