So let me start my tale of frustration and self doubt. As a longtime cryptocurrency user/investor I got the bright idea to try building a small mining rig since I have experience building gaming pc's. This was not a get rich quick idea but more a hobby that could pay for itself. So I did the research and decided to got with a MSI Pro Series SLI Plus Z270 ATX motherboard, Intel Celeron G3920 CPU, compatible 8gb's of ram, Corsair HX1000 Watt Platinum PSU, and Onvian Mining PCI-E risers. I also started with two RX 580's 8gb (Sapphire Nitro+ SE & Sapphire Pulse).
So here we go.
About two weeks ago I get my new motherboard and start building my mining rig. I get everything installed correctly (I think) and get ready to power it on. I click the power button and I get about a second of power - GPU's briefly buzz - and then nothing. I look around the board and realize that I forgot to plug in the CPU power connector from the PSU into the motherboard. (Complete noob mistake that I shouldn't have made but I din't think it could fry the board) So I plug the CPU connector in and hit the power.... Nothing... no indicator lights... never even posted. So I start trying to troubleshoot the problem - nothing worked. I reset the CMOS, unplugged everything but essential equipment, did the paper clip test on the PSU (It worked fine). I finally contacted the retailer and requested a replacement.
A few days later my replacement arrives - I surgically install everything and triple check every connector. I hit power and boom - everything is booting up!!! I almost start crying tears of joy as my rig starts humming along.
About two weeks go by and everything is working like a charm. I've modded the vbios on the GPU's to squeak out some extra MH/s and decide to order a third GPU.
Yesterday my third GPU (MSI RX 580 Gaming X 8gb) arrives and I plug it into my third PCI-E riser and start connecting all the power connectors - since I ran out of 6 + 8 connectors I used the 6 pin to SATA connectors that came with my risers and plugged two of my risers to the PSU (single cable for each one). I then used a 6 + 8 pin on the new GPU. After checking all the connections I hit the power button - and I once again get about a second of power - a click - then everything is dead.
My question to the community is what am I doing wrong or am I just really unlucky? I've built several gaming PC's that have never once had a problem. Are the cheaper motherboards really this fragile? Could the risers be causing a short on my motherboard? Does anyone else have any theories on what I'm doing wrong? I'm desperate for help at this point...
So here we go.
