Last week my PC wouldn't post. The fans would spin, the lights would turn on, but no image would appear.
So I thought it was my GPU because my GPU had already been repaired. Bought a 4070, didn't work.
So I figured it was the motherboard. I was going to upgrade soon anyway, so I got a new PSU, a new cpu and a new motherboard
I went to turn it on for the first time without the GPU, VGA light turned on.
I tried my wife's ram modules and they didn't work either (they're working on her computer right now)
Current build:
i5-13400
Motherboard - MSI mag b760 tomahawk WiFi
32gb vengeance ram Corsair (got two 16gb modules)
PSU - rm750x shift by Corsair
The box on my motherboard says there's no need to update bios for 13th gen CPUs.
My previous build was an i7 10700kf, an MSI z490 gaming wifi edge motherboard, and an EVGA 750w PSU.
Please help, I have a job to do over the weekend and I was already freaking out because of the deadline as it was. The parts finally got here and now I don't know what to do.
FIXED:
So, after hours and hours and HOURS or research and trial and error, the culprit was the SSD with Windows installed on it. Don't ask me why or how. I've been building and helping friends build and fix their computers for almost 10 years. My wife came up to my work table, took a look and said, "Did you try disconnecting the SSD?" I told her that the VGA light shouldn't turn on because of that, but I'd give it a try since I had literally tried EVERYTHING else. BIOS booted up instantly.
I took the faulty SSD to a repair shop and although their system recognized the SSD, Windows wouldn't boot from it.
Anyway, if you've tried EVERYTHING from checking for bent pins, to reseating each and every cable, RAM module, even the CPU, and you're still getting a VGA light, then maybe it's one of your SSDs.
Hope this helps someone in the future.
Current build:
i5-13400
FIXED:
