Question Please help! Wifi Card issue!
Jul 28, 2020
Hi everyone, i have recently built a pc and everything was working great. I bought a wifi adapter because at the time i was using usb. The wifi card worked, but it had to be plugged out and back into the pcie slot in bios for it to work. I was also having an issue where shutdown didn’t work but that is now fixed. I have been having this problem for a few weeks now and it’s a hassle to open bios and plug the adapter out and back into the pcie slot. It’s not the slots problem as the other ones have the same problem. The card and motherboard are comparable with eachother, and there is nothing wrong with any of the other parts compatibility wise. If anyone knows a solution please let me know!
Update your post to include full system hardware specs and OS.
Are you sure that only one network adapter (either wired or wireless) is enabled?
As I understand your post you are using Wifi so that adapter should be enabled and the wired (ethernet) adapter disabled.
Run "ipconfig /all" via the Command Prompt and post the results.
