P pjmadguy Commendable May 30, 2016 14 0 1,520 May 30, 2016 #1 Will an FX-8320e possible OC via cm hyper 212 evo bottleneck an XFX R9 380 4gb? Thanks!!!
Solution clutchc May 30, 2016 pjmadguy : Will an FX-8320e possible OC via cm hyper 212 evo bottleneck an XFX R9 380 4gb? Thanks!!! Should be fine. But the R9-380 is probably as high as you'd want to go if occasional bottleneck is an issue for you.
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 May 30, 2016 Solution #2 pjmadguy : Will an FX-8320e possible OC via cm hyper 212 evo bottleneck an XFX R9 380 4gb? Thanks!!! Should be fine. But the R9-380 is probably as high as you'd want to go if occasional bottleneck is an issue for you. Upvote 0 Downvote Solution
