This is my first PC build, and I am unsure on what to get. Over the course of a week I have picked out some parts, but since this is my first time I am unsure if they match. Please tell me if these components match and work well together, also would you have some other suggestions for the sme components that are about the same price as mine?
GPU:
RX 5600 XT Sapphire - 290$ (https://www.newegg.com/sapphire-rad...XT&cm_re=AMD_RX_5600XT-_-14-202-364-_-Product)
CPU:
Ryzen 5 2600- 160$ (https://www.amazon.com/AMD-Processo...1&keywords=RYZEN+5+2600&qid=1589663177&sr=8-1)
CPU Cooler:
Cooler Master Hyper 212 Evo CPU Cooler (4 pipes) - 35 $ (https://www.amazon.com/Cooler-Maste...yper+212+Evo+CPU+Cooler&qid=1589663228&sr=8-2)
Motherboard:
MSI B450 TOMAHAWK GAMING PLUS MAX - 100 $ (https://www.amazon.com/MSI-Performa...s=MSI+B450+TOMAHAWK+MAX&qid=1589663524&sr=8-1)
RAM:
Viper Steel Series DDR4 16GB (2 x 8GB) - 70 $ (https://www.amazon.com/Patriot-PC4-...(2+x+8GB)&qid=1589664157&s=electronics&sr=1-1)
SSD:
WD Blue 3D NAND 500GB Internal PC SSD M.2 - 69 $ (https://www.amazon.com/dp/B07F9PWJM6/ref=twister_B0842PXR91?_encoding=UTF8&th=1)
HDD:
(I alredy have an ssd from another old computer)
Case Fan:
Cooler Master MasterFan MF120 Halo Duo-Ring Addressable RGB Lighting 120mm Fan - 30 $ (https://www.amazon.com/Cooler-Maste...120mm+Fan&qid=1589664597&s=electronics&sr=1-1)
GPU:
CPU:
CPU Cooler:
Motherboard:
RAM:
SSD:
HDD:
Case Fan:
