Please can anyone help me i have 1695
Available video card memory but in use is only 64 mb can u guys help me?
I tried to find bios but i cant idk what's happening? 🙁
And from where did you get this 64MB memory being used message? Coz the software application (games) will adjust according to their requirement. And I am guessing you don't have any other GPU installed in your PC.
Why do you need help ?
Your GPU is working normally.
That means you are using a very small part of the video memory and that's good.
It's always good to not stress your GPU, hence there's vsync.
Try running intensive games and you will see the memory usage rise to gigabytes of usage.
Sorry to say this but CS:GO requires GPU... its a discrete graphic card needed to play the game. So your Onboard Mobile chipset graphics is not going to let you play the game.
Get a new budget GPU and then you can play..
Minimum Requirements :
OS: Windows® 7/Vista/XP.
Processor: Intel® Core™ 2 Duo E6600 or AMD Phenom™ X3 8750 processor or better.
Memory: 2 GB RAM.
Graphics: Video card must be 256 MB or more and should be a DirectX 9-compatible with support for Pixel Shader 3.0 discrete Graphics card
DirectX: Version 9.0c.
Storage: 8 GB available space.
