Here are components being used:
EVGA GTX 980 TI SC+ that requires both a 6 pin and 8 pin power connection
Corsair AX760 platinum power supply
MSI Z370 Gaming Plus MOBO
I7 8700K
So I recently picked up the GPU and went to install it in my system and get "Please power down and connect the pci-e power cable".
The person I bought the computer from had thrown out all the spare PSU cables that he hadn't used, including the PCI-e cables. I knew someone who had cables from an HX1000 platinum. I contacted Corsair and they said the cables will work with my power supply. Despite this, I get the error message above. Could it be the cables and I need cables specifically for this power supply? I am waiting on a response from Corsair.
In the mean time, the computer still runs great using the integrated graphics card on the CPU. When looking at device manager with the 980 TI installed but using the integrated graphics, it shows up but gives error code 43. I tried installing the drivers provided by EVGA for the 980 TI but that didn't seem to do anything. The graphics card itself starts up, lights up and you can hear the fan on startup? What else could I possibly look for to fix this or what else could be the issue if it isn't the power cables?
I7 8700K
