Please power down and connect the pcie power cables MSI GTX 1060
th3lazylegend
Commendable
Oct 10, 2016
Hello,
I'm upgrading my GPU from an Nvidia GeForce GTX 670 to an MSI GeForce GTX 1060. The GTX 670 requires two 6 pin connectors. The 1060 requires an 8 pin. I was informed by the company I purchased it from, that it should be ok. However, when I powered up my PC I got a warning message saying "Please power down and connect the PCI-E power cables for this graphics card". So I am now unsure of a way forward. Could I have damaged the Graphics Card by using the 6 pin connector?
Any help would be great!
Thanks
Unlikely you damaged it but you will need an 8-pin connection for the card to work. You might be able to get away with using a dual 6-pin to 8-pin adapter as long as you don't get a cheap one with thin wires.
https://www.amazon.com/EVGA-6-Pin-Female-8-Pin-Cable/dp/B00M49SELW
Whats the make and model of the current PSU? If it's a lower quality unit you'd likley be best served replacing it as many low quality units have the potential to damage other components.
There is absolutely no reason not to use an adapter. It isn't like the power isn't coming from the same 12v rail anyway.
9 out of 10 PSUs just use a loop of wire to turn 6 pin to 8pin anyway. There is absolutely no reason not to use an adapter.
When the guys where you purchased the GPU said it was ok, they assumed you'd use the 2x6pin adapter that likely came with your new GPU. Also, when you power down, don't forget to also unplug the PC from the outlet. PC's for many years now maintain a small amount of power, even when turned off.
Replace ASAP you have a potential system killer power your rig. you should consider yourself luck it somehoe manged to power a 670 without starting a fire. Quit gambling and buy a decent PSU.
WTF, do not unplug your PC from the wall, switch it to off, but leave it plugged in.
If you unplug your PC you unground it.
His PSU is fine guys, jesus, he just needs 6+2 adapter, its like pennies at the store, all this confusion for a super simple answer. He has no real need to replace his PSU, they all have OCP, OVP, UVP, its ALL standard now guys. He is fine.
I have seen countless cheap PSUs( including Cooler masters) that supposedly had protections fry other componets and even entire systems it's one of the dangers of using garbage grade PSUs. It's not hate it's experience.
Thanks for your help, I'll look into getting a new PSU, didn't even realize that it would struggle to run the 1060.
If it will run a 670 it will run likely run a 1060, that's not the problem. The problem is the unit is a ticking time bomb and when it eventually fails it has the potential to take other parts with it.
Why you shouldn't use a low quality PSU is not a lesson you want to learn the hard way as it can get rather expensive.
Interesting video. Wonder how he calculated load and if it was all on the 12v rail or what, if you draw 300w through 5v any PSU would pop.
Popping is generally good. Saves the system. There would be no pop if the fuseable links and shunts didn't exist. Just like when your house breaker pops, or a fuze in your car gives.
A lot of low quality PSUs fluff their numbers making the max load impossible to achieve.
Fact is his PSU isn't those in the video and works just fine as is.
All native 6+2 pins are physically identical to a 6 to 8 pin adapter.
Why would it be unsafe? It's literally just 12v and common lines, but 2 more of them.
They are included with new GPUs even though they are unsafe? I mean... It's not like the throughput is going to exceed the rating for the gauge of wire.
Its just for the GPU's wants. There is ostensibly no difference between the draw on a 6pin GPU versus an 8 pin gpu.
Is 1x 8 pin more dangerous than 2 6 pins? Of course not. Is 2 8 pins somehow dangerous? No. There is really no difference, all these wires connected to a single 12 volt rail anyway.
1) the v2 unit is on 4 from the cooler master 500w http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
and that one is bad the one op has hasnt got even a review on a website because its that bad.
so yes its a timebomb.
2) thats psu gets used to a patern and can that wear and torn psu cant handle a new voltage .
3) that psu gives already unstable voltages now lets convert it to an 8pin adapter which draws more power, its not smart and besides that I cant find it but i remember psu experts like blackbird dont recommand adapters.
You are aware that doesn't mean anything right?
