Please rate build for a nephew who will study for GCSE
thexxx
25
Hi there i am trying to build a budget PC for my nephew who mainly will use the computer to study also with intention for playing some games such as GTA V or Fortnite (For now without GPU) due to fact that he has to study!
I am thinking of this build there
https://uk.pcpartpicker.com/list/ckcsMZ
Since my last build was in 2015 i am little bit out of date with components can someone help me and rate that and give me your feedback what would i change many thanks
If you cant get a gpu, you should probably look at amd APU's. For example this one here: https://www.newegg.com/Product/Product.aspx?Item=N82E16819113481&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Processors+-+Desktops-_-N82E16819113481&gclid=Cj0KCQjwz93cBRCrARIsAEFbWsgv9fdVaDENHfL4MsARlUqtBWt4-M9j_wUhzvYVUiws4Cv93GQ8p6kaAmtmEALw_wcB&gclsrc=aw.ds
the 2200g has 2 more cores than the i3, and has VEGA graphics built in, definitly enough to play fortnite and GTAV(the intel cannot play gtaV on its own.) Additionally b350 or b450 motherboards are equally as cheap as the intel board, which is all you need to run the 2200g. Just be sure that if you get a b350 it has the updated bios to support the newer amd...
the 2200g has 2 more cores than the i3, and has VEGA graphics built in, definitly enough to play fortnite and GTAV(the intel cannot play gtaV on its own.) Additionally b350 or b450 motherboards are equally as cheap as the intel board, which is all you need to run the 2200g. Just be sure that if you get a b350 it has the updated bios to support the newer amd APU included in the box.
do u think that then would be better?
https://uk.pcpartpicker.com/list/v6s7MZ
also how do i make sure that the bios is updated to run that cpu thanks
You can contact the seller and ask about the bios. But it's probably better to just grab a b450 board. It will save the trouble of having to deal with it. They are in the same price range now
