I need to know your opinion, and what would you change, and if this will even work or run, just your advice. thanks!
Ultra LSP650 650-Watt Power Supply
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276573&sku=ULT-LSP650
AMD HDX945WFGIBOX Phenom II X4 945 Quad Core Processor - 3.00GHz-
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4615717
AGAMA K-220 31310043101 Easy Comfort Multimedia Keyboard
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=5999562
Microsoft SideWinder X3 Mouse - 4.5" Length
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4914872
Cooler Master Centurion 5
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=1482411
EVGA 768-P3-1360-TR GeForce GTX 460 Video Card
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=6514068
Acer G215HAbd 22" Class Widescreen LCD Monitor - 1080p
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6256825&sku=A179-2268
PGV34G1333ELK Sector 5 4GB PC10666 RAM - DDR3
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5546850&sku=P33-7114
Lite-On IHAS124-04 Internal DVD Writer
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4829307&sku=L12-1312+OEM
Western Digital WD5001AALS Caviar Black Hard Drive - 500GB
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4914330
