Plese Help, Keeps crashing
daleevr
29
Hello Everyone, I keep getting this error message when I play Goast Recon 2.
Crash in application version: 30899.3048
Unhandled exception - access violation
C STACK:
graw2 (???) : ???
graw2 (???) : ???
SCRIPT STACK:
data\lib\units\types\weapons\bulletweapon.dsf(0)
data\lib\units\ai\soldier\sgunlogics.dsf(0)
data\lib\managers\aihivebrain.dsf(0)
data\lib\setups\setup.dsf(0)
data\level\level.dsf(0)
Renderer: threaded
Physics : threaded
I have:
9600gt 1Mb
9450 processor
4 gigs ram corsair DDR3 1333
DX38BT intel board
Can anyone tell me why I get this. Thanks in advance for your help!
Dale
First question: Have you downloaded & installed all the GRAW2 Updates?
Second Question: Have you checked the FAQ or Forums page for Ubisoft? (I think Ubi is the one who did GRAW2 anyhow). If it is a common error code you can usually find an answer to your problem pretty quickly that way.
http://ghostrecon.us.ubi.com/graw2/ Game Website
http://www.ubi.com/US/Downloads/Info.aspx?dlId=2265 Patch List (Current is 1.05)
And you said you have a "9600gt 1Mb" video card. I'm guessing you meant to type 9600 GT 1GB. :)
Yeah just searching Ubisoft's Graw2 Forums for "30899.3048" I find lots of entries with people having similar crashes. Looks like there may just simply be a bug or something.
Best bet is probably to skim their forums for an answer, or contact Ubisoft directly.
