Plexor PX-128M8PeY - Read/Write (1gb/100mb) Confused
ursocheap
6
I wanted to upgrade my system with a PCIe NVMe SSD. Basically, I went through the process of reinstalling windows 10 onto this new SSD.
Once the deed had been done I went to check my speeds and they were coming back with 1gb read 100mb write as you can see below.
JaM4m
Not sure if the image posted using the [-img] [-/img] format so here is another link to imgur
http://imgur.com/a/JaM4m
I thought initially that it was because I had the Card installed in a x8 PCIE port so I moved my graphics card down a notch and installed the SSD into a x16 port. Unfortunately this did not do anything for me.
Finally, I have been reading how to install these cards and I cant seem to find anywhere that describes what settings to use on my x99A Gaming Pro Carbon motherboard. I have UEFI + Legacy boot enabled and that's about it.
I am not assuming that I know anything so any help is appreciated my specs are as follows.
i7 6800k
Gtx 1080
16gb DDR4 RAM
Crucial SSD
Plexor PCIE NVME SSD
2 x HDD
I just want to figure out how to fix this issue any help is appreciated!
