G
Guest
Guest
I just got a Plextor 12/10/32A EIDE drive, for my athlon 700. I also have a shuttle DVD rom drive both on the secondary IDE channel. The primary channel has 2 hard drives. This is all connected to an EPOX KX133A MB.
So anyways on to my problem. I just installed the new burner it is the master on the channel, and the DVD drive is the secondary drive. I used to have an HP 2x burner that worked fine in this configuration, however now the Plextor gives me random errors while trying to duplicate a CD. It does this in both DupeCD and Adaptec DirectCD. What happens is when I try to do a direct copy without copying to hard drive first it gets to 80-90 percent completed and then gives me a write error. One time it gave me the error 'commands not sent in sequence'. Further when I do specify to copy to the hard drive first, the DirectCD program just freezes while trying to copy from the DVD drive to the hard drive.
These errors all occur in the Adaptec DirectCD program, when using the plextor CDDupe program it simply freezes on direct copy, and on create image. Sorry for the lengthy post just trying to provide as much info as possible, any help would be greatly appreciated.
