SO WHAT HAPPEN IS FEW DAYS AGO MY COMPUTER DIDN'T BOOT UP AFTER BSOD. IT SHOWS NO SIGNAL ON MONITOR SO I THOUGHT ITS THE VGA TO DVI ADAPTER THAT IS BROKEN. THEN I BOUGHT THE NEW ADAPTER YESTERDAY. AND I THOUGHT ITS THE RAM
I PLUGGED THE NEW ADAPTER BUT IT DOESN'T WORK. I TAKE OUT THE GPU THEN PLUG IT THE VGA TO THE MOTHERBOARD AND IT WORKS. THEN PLUGGED THE GPU AGAIN AND IT DOESN'T WORK TRIED TO CLEAN IT EITH ERASER. THE IT MAGICALLY WORKS. AFTER 20-30 SECONDS OF BOOTING UP I GOT BSOD AGAIN. THEN SHUT DOWN AND NO SIGNAL AGAIN
BOARD VGA - WORKING
BUT WHEN I USE MY GPU NO SIGNAL SORRY BAD GRAMMAR PLS HELP THANK YOU
BOARD VGA - WORKING
