Question Pls help me choose a Graphics Cards
4
Hi everyone, i need a graphics card for my pc. But i can't choose. Help me choose the best Graphic card for me =(
My pc specs:
OS Name: Microsoft Windows 11 Pro
OS Version: 10.0.22631 N/A Build 22631
Motherboard: H81M-DS2
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed. (Intel Core i3-4160 @3.6 Ghz)
BIOS Version: American Megatrends Inc. F1, 9/2/2014
Ram: 3,978 MB
My pc in in living room (in a ATX case). I am not short of money. PSU 400W. 1 slot PCIe.
--If you need more, contact me--
Where are you located? What is your budget for your GPU purchase? Preferred site for purchase? Make and model of your PSU and it's age(in case your PSU will be a limiting factor)? Cases' make and model(in case you have clearance issues)?
I wouldn't go over anything like a GTX1050Ti, due to your processor/platform(I'm assuming your PSU isn't up to par either).
Why do you think you need a graphics card?
Your pc motherboard has integrated graphics.
I suspect that a GTX1050ti would be an appropriate card.
A graphics card of any type will use only the one pcie slot that you have.
But, most graphics cards will occupy the space of two or more slots.
That is not a restriction with a ATX case.
To go for a much stronger graphics card, you will also need a psu much stronger than the 400w that you have.
650w 60 850w depending.
My pc specs:
Ram: 3,978 MB
You might want to add ram to your upgrade mix.
