pls help me upgrade my pc to run bf4 on 1080p
aditya_kashyap
Here r my pc specs
Cpu intel i5 3rd gen 3.1ghz
Gpu gt 630 1 gb ddr5(will buy 750ti)
Psu 450 watts 19 A stock(will buy vs 450)
Ram 6gb 1600 mhz
Ya now pls tell me that can i run bf4 on 1080p on low-medium with 60fps.
And do i need to buy psu vs 450 to run 750 ti.and do i need to upgrade my ram to 8 gb
A 450w PSU should power that 750Ti just fine. As for RAM, the more you have the better off you are as 8GB seems to be quickly becoming the standard.
What OS are you running? BF4 seems to run smoothest on W8/.1.
The GTX 750 Ti is better than the non Ti. Since a graphics card is not something you upgrade everyday, it is best suited to buy the most powerful for the price you are paying.
Just go with the Ti, you won't regret putting in the extra money.
Buy the best you can afford. If it means waiting a bit longer to save up a little more cash, just wait. No sense in settling when you don't have to do so. That said, perhaps you should wait a little bit longer anyway seeing the 960 is supposed to be out later this month. It'll be far better than the 750Ti.
No doubt. But I guess the 960 will be significantly costlier than the 750 Ti. The price difference would be 'more than noticeable'.
