pls help with my 1st build attempt
zedsdead101
I am about to try to build a gaming pc myself for the first time, would appreciate any help on the parts I selected. Will these components work well together?
psu: EVGA Supernova G2 850W
cpu:i7-7700k
gpu: MSI GeForce GTX 1080 Founders Edition
ssd: SAMSUNG 950 PRO M.2 2280 256GB PCI-Express 3.0 x4 Internal Solid State Drive
(I only play 1 game at a time really, so just getting the one small ssd)
mobo: ASUS ROG Maximus IX Hero LGA1151 DDR4 DP HDMI M.2 USB 3.1 ATX Motherboard
cooling: Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU Cooler
case: Corsair Graphite Series 780T Full Tower PC Case
RAM: I was looking for 32g of gskill ripjaw ram on newegg but it seemed like they were for z170 mobos, I couldn't find anything for z270, any suggestions for what to do for ram?
Both Z170 and Z270 use DDR4 RAM, so any DDR4 RAM won't cause any incompatibilities. Your build is great, but I will give you some advice to save money:
1) The sweet spot for a GTX 1080 is 750W (650W if it's Founders' Edition). 850W will be a waste except if you're planning on SLI in the future.
2) You will be playing with your PC for years, so the 1 game argument is most likely invalid. You're going to need more storage than 256GB. My advice for this is to run Triple Drive Setup. Buy 128GB M.2 PCI-E SSD for Boot Drive and crucial programs, 256/512GB for games, and 1/2TB for Media Storage.
3) It all comes back to preferences, but you can get a better case for a cheaper price. Try searching for Phanteks Eclipse P400s, Corsair 400C, and NZXT S340 (some of my favorite cases).
7700k ~ 120-140W maximum depends on the silicon quality.
GTX 1080 ~240W maximum with the usual caveat for graphic cards, ~20% or higher spikes can be observed frequently for their "boost" ability.
So, realistically, if you're getting PSU as high quality as the EVGA supernova G2, a 550W is enough for single GPU setup, 750W is just enough for SLI setup (the updated EVGA G3 750W is at special price $99.99 @ Newegg for a few more days), 850W for more breathing room (and spikes).
Personally though, unless you're getting that Founder Edition for cheap, get a branded (MSI Gaming X, Gigabyte G1 Gaming, ASUS STRIX, Zotac AMP! Extreme, etc) card instead.
And try to get the 960 series SSD. While real-life performance difference would be negligible, the 960 have certain form of heatsink on them that would help them avoid running too hot and be thermal throttled.
Also, if it's available to you, get the Arctic Liquid Freezer 240 instead of the H100i as it is cheaper while offer more cooling performance.
@ID
Neither the P400S nor the S340 are a good pick for 240/280mm liquid. The S340 can't use 240mm rad for top exhaust (more cooling and less noise than having to use them at front), the P400S for not having enough clearance between the top and the MB/RAM to mount an AIO. The 400C while good, is way more expensive than the Phanteks ProM, you can easily get even the version with full sized Acrylic window for less.
And if he can put his PC together, adding extra SSD/HDD is no trouble at all.
Crucial Ballistix is also a good option.
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=Ballistix&ignorear=0&N=100007611%20601190328%20600006072&isNodeId=1
You'll likely only need 16GB of ram for now, and can always add more later off if you need it.
I actually have the "grey" model, which actually has a very nice brushed-aluminum finish on the top, and is more color-neutral than it looks in the photos once you install it.
So far, I've had mine for nearly a year, and it seems to be holding up well for being mid-ranged ram.
As far as cases are concerned, I would suggest a Corsair Vengence C70 instead:
https://www.newegg.com/Product/Product.aspx?Item=N82E16811139013&cm_re=Corsair_Case-_-11-139-013-_-Product
It's a bit of an older case, but the support for topmounting radiators is much better.
I personally own a C70, as well as the 780T and it's little M-ITX brother the 380T(as a travel rig),
and another one of it's problems is that the restart button is very easy to hit on accident, as it's very out in the open, and as large as the fan control button on the IO panel.
The C70 is much better in this regard as it actually has a little protective cover for the restart button.
A sort of minor + , but still something to keep in mind.
If you are into the military-chic look, there is also a green option for the C70 as well.
On PSU, would strongly recommend a Corsair RM750X over the EVGA G2 850W.
I know they are the same price(at least on Newegg), and the Corsair is 100 Watts less,
but the Corsair PSU is UL certified, which is usually a mark of more safety/quality engineering and manufacturing standards. (I have a CS/Electrical Engineering background).
In my experience, UL cert PSUs are much more reliable and have a much smaller chance to fail or develop things like coil whine over the long-term.
As far as cooling, stick to the Corsair H100i V2.
While they may not perform on paper as well as some of the other coolers out there,
they tend to be less leak-prone(But not leak-proof mind you), and have less instances of pump failure.
With that being said, you might want to consider looking at some high-end air coolers(Like a bequiet! or as an alternative, with this being your first rig and all. As if G-d forbid you do ever get a leak, and it ruins your CPU and Motherboard, you may be without a PC for a while if you don't have the money on hand to get replacements.
A Titan X (Pascal) would draw 275W at most, so you'll still have plenty. But nVidia is poised to release the GTX 1080 Ti soon, if you haven't bought the standard GTX 1080 yet, then the Ti version would probably be better pick than the Titan X; if you already bought a GTX 1080 then unless you have very specific demands for the build, neither the Ti nor the Titan X produces enough performance benefits that is worthy of the price differences.
