Windows 8.1
16 BG RAM (2 sticks vengeance ddr3)
Intel i7-4790K (Not overclocked and I won't be)
Motherboard GIGABYTE Z97-HD3 LGA 1150 rev 2.0
GeForce GTX 1050ti not overclocked
PSU: EVGA supernova 650 Watt G2 80 plus Gold.
case: rosewill line glow mid tower atx.
my PC case's front panel USBs are faulty, they caused restarts.
I air cleaned the circuit board in the front bezel and checked wires and everything looked ok, but is faulty, so I unplugged the front USB hub from the motherboard (the USB 3.0 jack that connects to motherboard and two 2.0 F-Case USB connectors to motherboard) and then moved my front USBs (keyboard, mouse, audio interface) all into the back USBs direct to motherboard. It hasn't restarted for months since I've done this.
I want more USBs and will get a powered hub. Is it ok if I connect a powered hub into 1 back motherboard USB and run all USBs through that, or will it lag or something and I should also use the jack on the motherboard which is meant for front-case USBs or an expansion USB card?
Things I will plug into the hub are printer, audio interface, SD card reader, not too much stuff, and the keyboard and mouse.
I'm referring to the blue USB 3.0 connector shown in the second picture
http://www.tomshardware.com/answers/id-2845990/angle-female-header-usb.html
Mine was using that blue jack for the front case USB 3.0 and also two more jack for F-USB 2.0. I disconnected all them because of the restarting problem.
I need a powered Hub regardless so I figure, even though it's nice to have quick front USB access, it's a waste of money if I don't NEED to also use that F-USB ports on the motherboard.
