I accidentally plugged my fan led into the CLRCMOS pins on my motherboard, when I turned on the computer the fans spun then turned off, now I cant turn the computer on at all.
Does that CLRCMOS have 3 pins ? If so there should be connector across two of them. Check MB manual but it's usually pins 1 an 2 for normal running and 2 and 3 for CMOS/BIOS reset.
It's only got 2 pins, I let the board sit overnight while unplugged but that didn't help. I think its bricked
