If it`s a new system, make sure to download and install two programs first or the webpages will not display properly.
The two bits of software you need to install are here, please click on both links.
Download the software and install them on your computer.
Java.
http://java.com/en/download/index.jsp
Adobe flash player.
http://get.adobe.com/flashplayer/
Some websites will not display properly untill you have these two bits of software installed.
It work after that ok.
