Question plz help with pc gaming build
May 29, 2023
hello I'm not new to pc gaming however not the greatest when it comes to parts. I have a fairly old pc but tired of unable to play new games so getting a whole new pc. i am just trying to get peoples ops on my builds if I can better optimise them, for the money, or if I'm cheeping out on the areas that would help me the most. and what set up would be better for gaming on.
Case
CORSAIR iCUE 5000T RGB MID TOWER GAMING CASE
Processor (CPU)
Intel® Core™ i7 16-Core Processor i7-13700K (Up to 5.4GHz) 30MB Cache
Motherboard
GIGABYTE Z790 GAMING X AX (DDR5, USB 3.2, PCIe 5.0) - ARGB Ready
Memory (RAM)
64GB Corsair VENGEANCE RGB DDR5 5200MHz (2 x 32GB)
Graphics Card
24GB ASUS TUF GEFORCE RTX 4090 OC EDITION - HDMI, DP
1st M.2 SSD Drive
4TB CORSAIR MP600 PRO NVMe PCIe M.2 SSD (up to 7000 MB/R, 6850 MB/W)
2nd M.2 SSD Drive
Power Supply
CORSAIR 1000W RMx SERIES™ - MODULAR 80 PLUS GOLD, ULTRA QUIET
Processor Cooling
CORSAIR iCUE H150i ELITE CAPELLIX XT RGB High Performance CPU Cooler
Operating System
Windows 11 Home 64 Bit - inc. Single Licence [KUK-00003]
or
Case
Processor (CPU)
AMD Ryzen 9 7950X 16 Core CPU (4.5GHz-5.7GHz/80MB CACHE/AM5)
Motherboard
GIGABYTE B650 AORUS ELITE AX: (WIFI 6E, DDR5, USB 3.2) - ARGB Ready!
Memory (RAM)
64GB Corsair VENGEANCE DDR5 4800MHz (2 x 32GB)
Graphics Card
24GB NVIDIA GEFORCE RTX 4090 - HDMI, DP
1st M.2 SSD Drive
2nd M.2 SSD Drive
Power Supply
Processor Cooling
Operating System
Thanks
Totally depends on the games you play most. On some games the 7950x scores a bit higher while on others the 13700k does. The majority of games out there are not well optimized to use more than 8 or 10 cores anyhow but since both these CPUs have 16 cores, but the 7950x has support for 32 threads compared to the 13700k's 24, then on those games that can use about every thread you can throw at them that CPU will do a little better.
Otherwise these builds are nearly identical and if we're being honest I'd simply go with whichever one was cheaper because they are both going to have excellent gaming performance and neither of them is really significantly better than the other overall or on average. I think the kicker here might be that the Z790 boards likely have some features you won't find on the B650 because the Intel Z boards usually are a little more feature laden than the AMD B series boards but I haven't directly compared anything against the B650 chipset boards yet so you might want to just look at some comparisons of the Z790 vs B650 chipset to see if one has something you require that the other does not. Likely, that's not going to be the case, but you never know.
Otherwise, there is really no difference in these builds so it really doesn't matter which one you go with. Go with whatever costs less.
Reactions: dunte11
