Archived from groups: alt.comp.periphs.scanner (
More info?)
To RSD99 my sincere thanks for your helpful posting.
The one part of the calibration process I'm still unclear about is which
knobs to turn to make an adjustment. I had been focusing on the Twain
interface, but you seem to be suggesting the settings in PhotoShop for the
RGB --> CYMK conversion.....is that correct?
Josh Page
"RSD99" <rsdwla.NOSPAM@gte.net> wrote in message
news
😱PKyc.14683$H65.5683@nwrddc02.gnilink.net...
> You are apparently just beginning to find out why soooo many people talk
soooo da*# much
> about "Color Management."
> First, a couple of random thoughts about your posting, and predicament.
Some of the things
> you need to consider are
> (1) HOW are you getting your CYMK measurement(s). All scanners ever made
work natively
> (internally) in RGB. If you are loading the image into PhotoShop (or any
other image
> editing program) and measuring the patches with the eye-dropper, WHAT are
the settings in
> PhotoShop for the RGB --> CYMK conversion? Note that there essentially are
an INFINITE
> VARIETY of these conversion factors available for this translation in
PhotoShop,
> PhotoPaint, or other image editing program.
> (2) OK ... you've just gone to the time and expense of purchasing some
Pantone color
> chips. You get a 'Very Good' for effort, but you have NOT gotten the right
thing to
> analyze your situation. Why? Several reasons.
> First:
> There is always very significant "color contamination" in any and all
printing inks, and
> Pantone color chips are made with printing inks. What you describe is
fairly normal for a
> Cyan (printing) ink.
> Second:
> The Pantone Color Chips are not designed to be used for "calibration"
applications. You
> need something that is. That would probably (best case) be a calibrated
IT8 target. They
> are *expensive,* but available from several vendors.
> A usable solution might be getting something like a Kodak Q13 Grayscale /
Color Patch
> set. They are *not* calibration / analytical grade, but they work pretty
well for getting
> you into the ball-park. Cost would be about $20 ... and they are available
form some of
> the larger photography suppliers ... for example, I *think* I've seen them
at B&H. Another
> option would be to get a Gretag-Macbeth Color Checker, which is often used
in the
> photography field, and is pretty consistent. Cost would be something like
$70 ... and they
> are available form some of the larger photography suppliers. The
difficulty with both the
> Q13 and The Color Checker is getting accurate numbers for what they
*should* read.
> Note that recently there has been a rather long (and very interesting)
discussion of the
> use of exactly these color "standards" in the Color Theory list hosted by
Dan Margulis.
> Incidentally ... any of his books are well worth reading.
> http://groups.yahoo.com/group/colortheory/
> As a point of reference, I just scanned the color patches on one of my
Kodak Q13 Color
> Patch targets. Here are the measurements in RGB ... I'm not including
measurements in CYMK
> because my conversion setup is probably quite different than yours.
> Numbers are on the PhotoShop 0-255 scale.
> Cyan Patch
> R = 41
> G = 159
> B = 200
> G = 128
> Magenta Patch
> R = 211
> G = 35
> B = 107
> G = 96
> Yellow Patch
> R = 238
> G = 215
> B = 68
> G = 206
> Additionally ... you asked:
> "... Am I right in thinking that my inexpensive 8 year old Epson needs to
be replaced?
> I just replaced my old scanner with an Epson 4870 PRO ... and yes, (IMHO)
it really *is*
> worth it.
> "josh" <josqb@cinci.rr.com> wrote in message
> news:E8hyc.78261$DG4.61908@fe2.columbus.rr.com...
> > I've been struggling to fully understand the poor color representation
of my
> > scanned and later printed color photos. After looking at the printer end
of
> > the process I'm now looking at the scanner. I recently scanned genuine
> > Pantone color samples
> > of pure cyan, magenta and yellow and then used Photoshop's eyedropper to
> > analyze the samples on its cymk sliders. The result for the cyan sample
was
> > c-79% m- 21% y - 8% k- 0%.
> > The other colors had similar "contamination". Am I right in thinking
that my
> > inexpensive 8 year old Epson needs to be replaced?
