Port Forwarding/ Bell Home Hub 3000
mrkudoman
16
Hello there, i'm trying to port forward a minecraft server, i've done this before so when i port forward both ports 25565 and 19132 using my ipv4 ip address it doesn't work. i just tried this on another router i have sitting here and it works on it, the only difference is that it slows my download speeds to a snails pace so i'd much rather use the home hub 3000 bell provided me with for the higher speeds.
ok thanks i tried it and both ports are said to be closed yet this is what my port forwarding screen looks like
maybe this is an issue with the ipv4 ip i'm using?
no repeater, i've deleted the other two and the port still shows as closed?
but this is what the router is saying. i am confused as to what i am doing wrong?
Ok, can you show me what your routher settings look like when they need you to fill it out? And also provide me with your Ipv4 address, can be found by doing ipconfig on your cmd. Also give me the port and everything.
so this is what it looks like, with my ipv4 in the input fields
Can you portforward with a wireless device for me? I'm curious, because I used to portforward all the time but now im using wired connection and it doesn't work. If you could somehow do that, that would be cool if not Ill find a way to test it out in the morning with is 7 hours from now
