I've posted this on another forum earlier, but no replies, so I hope I can responses from you guys
The day after I posted that, I tried testing more things:
OKay, I read that port 80 should always be open because that port is what allows me to connect to the interwebs? But then I'm more confused because of how if I don't manually open the ports, then the port checker says my ports aren't open.
I have tried disabling UPnP on both modem and router, restarted both, but still no worky.
I also tried enabling UPnP on modem, and disabled on router, and also vice-versa, restarted both, and still doesn't work.
I did a bit of searching about my specific router, and other ASUS routers. In one or two threads, they have disabled a setting known as "Nat/Hardware Acceleration". I tried disabling that, rebooting my router, and still no luck.
Here are some images of my modem/router settings:
Router Portforwarding:
Yes, that IP is my PC's IPv4 address listed in cmd>ipconfig
Overview Modem Port Forward page:
Example of ports I forwarded to my router (CSGO PORTS):
Any help would be very much appreciated
thanks!
Let me know if I need to provide any more information
Hello!
In simple words: I can port forward port 80, but not other ports such as 27015.
Okay, so a couple of months ago, I purchased an Asus RT-AC68U router to connect to my modem/router, a Technicolor TG589vn v2.
I have my modem connected to the wall thing, and my router connected to the modem. Other devices are connected to the router, and so as my computer via ethernet.
I want to host dedicated games such as CSGO and Terraria, but I need to forward some ports.
So, on my modem, I port forwarded the appropriate ports needed for both games. The device I forwarded the ports to, is to my router, because that was the only device listed. Now on my router, I forwarded those same ports to my computer, my IPv4 address. I applied all settings, and went to Open Port Check Tool to check if my ports were opened. I tried 7777 (Terraria), and the ports were closed. I thought maybe that it took some time to refresh, so I started up my Terraria server. Once the server was up, I checked the ports again, and they were opened.
I then checked the CSGO ports (27015), and they were not open. Odd. I could play Terraria fine, and with my friend as well. Though after I closed the server, and used the port checker again, it said that my ports were now closed...?
So next, I tried CSGO. I started up my server, and tried to connect to the server using a command "connect [external ip]:27015". And I could not connect to it.
I then tried to experiment port 80. I opened port 80 on both the modem and router to my computer and it worked. But before I did open that port, it said that it was closed. I unassigned port 80 from my router, and checked to see if the port was still open, but it wasn't. I opened it again, checked it, and it worked.
thanks!
