Have you verified that the router has a public IP address? The WAN address listed in the router must match https://whatismyipaddress.comI have finnish named provaider named "DNA", so I haven't found information about port forwarding. Even the fact that there is no tutorials in internet I still tried to do it. I have tried everything that is free but nothing seems to work. I would like to have help
What is public IP address?Have you verified that the router has a public IP address? The WAN address listed in the router must match https://whatismyipaddress.com
And where to find WAN address list?Have you verified that the router has a public IP address? The WAN address listed in the router must match https://whatismyipaddress.com
My public IP and WAN adrresses do matchHave you verified that the router has a public IP address? The WAN address listed in the router must match https://whatismyipaddress.com
No. Some ISP have a router between your router and the public IP. So your router gets a private IP or something called "Carrier NAT" IP.I'm bad at english and I thought that every router has public IP, so I wanted to confirm, that I understand correctly
OK. For the port checkers to show an open port, the server has to be running. You can't test port forwarding without something running and listening on the port.I want to make MC server
I have already tried doing thatOK. For the port checkers to show an open port, the server has to be running. You can't test port forwarding without something running and listening on the port.
For us to provide much more insight, you will have to screen copy the port forwarding page on your router. Post that picture to imgur (or other image hosting service) and post a link here so that we can see what you see.I have already tried doing that
Your forwarding looks OK. Have you read anything like this -- https://www.hostinger.com/tutorials/how-to-port-forward-a-minecraft-server
Wirelesshow is your router connected to internet, wired or wireless?
in that case port forwarding wont do anything as you are on NAT3 which is common on large networks as wifi/LTE/5G isWireless
So what should I do?in that case port forwarding wont do anything as you are on NAT3 which is common on large networks as wifi/LTE/5G is
port forwarding needs to be either configured on your ISP hardware or you will need external server
Oh sorry, I read the question wronghow is your router connected to internet, wired or wireless?
