portable computer box with highest port
Nov 3, 2016
14
looking for a portable computer box with the highest amount of ports that can be connected to a display, sound system, keyboard, mouse, projector and other hardwares. it has to be a computer box.
So a Bitfenix Prodigy.
https://www.bitfenix.com/global/en/products/chassis/prodigy/
Even has handles.
Not really sure what you are looking for, a computer, a set top box, a laptop, an android device, etc... Really all are "computer boxes" aside from maybe a basic cable TV set top unit.
If you buy a tower computer system you can put in as many ports as add-on cards and external hardware that will fit on a motherboard, which is quite a lot. You can put a few video cards in, an internal or external sound card, have a ton of USB ports on it. It may help if you post what exactly you are looking to do with this thing.
Your single 'requirement' is rather vague.
You're looking for a computer case?
Must be small, but with a lot of ports?
Number of 'ports' also depends on the motherboard. SATA ports, for instance.
What is your definition of 'portable'?
carriable in one hand with average muscle build and does not require two hands to carry.
Even has handles.
if i use the pick as solution option, will this thread be locked?
No, other people can continue to comment.
selected as it caters to the demand. i was also referring to this as well, if your said solution did not exist in world at present https://en.wikipedia.org/wiki/Single_board_computer
provide help for this version of computer box
The link goes to very small motherboards with few ports. You should specify exactly what you are looking for and for what use and what ports you want. Do you want smallest if it means less ports? How many exactly are you looking for as the minimum for connections and what connection types? You need to provide specifications to get answers. Just saying "small with lots of ports" is too open ended and can have dozens of answers.
Your question should be "I need to do ____, connecting to ______ equipment with _____ connection types and _______ size/cost limit, what can I get". Saying things like "lots of connections" and "small" leaves a lot of other questions that we need to ask. If you are looking for a full small computer, prices can go from a few 100 to several 1000 depending on your needs.
you just will not stop trying to feed your mistake to me. in OP i specified portable, try carrying an ATX setup or larger with one hand only. i said highest number of ports, no less. i did not ask you to tell me to state budget limit, i will not. i have stated my demands and usafret provided it correct to the point, how did that person manage it? by reading the OP and understanding what can be carried in one hand and have highest number of ports.
highest number within that mass. i did not ask highest number of ports only.also check my new reply.
