portable hard disck drive 1t
Madalin_1
Hello I have a 1T portable hard disk and I think I've broke it. I've put in it the resotre windows files and it has gone from 1T to just 31.9 maximum capacity and I don't know what to do. I've deleted everything and formated it and still nothing. What can I do so it will be 1T again?
Help please. thanks!!
Hey there, Madalin_1.
Would you please post a screenshot of what you see about the drive and its partitions in Disk Management (you can use imgur.com to upload the image). Here's how to access it: How to access Disk Management in Windows to manage hard drives.
On the other hand if you don't want to wait for me to see the screenshot and post a reply, in the meantime you could try low level formatting (write zeros), to see if that fixes the issue. You could do that either by using DISKPART or the HDD manufacturer's diagnostics tool (most of those tools support low level formatting). If you decide to go with DISKPART here's how to do it:
1. open CMD (Command Prompt) as administrator
2. type in diskpart and press "enter"
3. type in list disk and press "enter" (This should list all available disks on your computer) If you don't know which of the listed disks is the HDD, you can identify the device by its size which is shown. If your device does not appear, try list volume instead. In this case, you'll need to replace the commands below with "volume" wherever it says "disk."
4. Once you are sure which disk is the HDD in question, type: select disk X (where X is the number of the HDD) and press "enter". E.g. if the HDD you wish to format is disk 1 you should type select disk 1
5. After that type: clean all and wait for the process to finish. Note that this might take quite some time. When the process is completed there should be nothing left on your HDD, so please make sure you've selected the right one.
When you're done, you'll have to initialize, partition and format the drive as if it was a brand new internal HDD. Here's how to do that: How to initialize or write a signature to a secondary hard drive or Solid State drive in Windows and How to partition and format a hard drive on Windows and Mac OSX.
Hope that helps. Please let me know how everything goes.
Boogieman_WD
Latest posts
