I am hoping someone can help me.
So at about January or near February of 2018 I started to notice large dips in framerate in many of my games. Including Far Cry 3, World of Warcraft, and PUBG. I took it to my local computer store and they held it over night and told me it was my GPU since it was older. It was a GTX 960.
I saved up money and bought a GTX 1060. I see some increase in performance, but I still get about 10 to 15 FPS in boss fights on WoW and can't keep a steady framerate in PUBG.
All of my settings are at the lowest possibility. I have tried changing resolutions. Everything is installed correctly. I can't figure out what the problem is.
A few weeks after I noticed the dip in frame rate, I noticed that my CPU fan was not plugged in. So for about 2 years I have had a computer built, but the CPU fan has not been plugged in (I had other people build it for me for free). I plugged it in, and there has been no change at all.
If anyone has any information for me please give me advice.
CPU: Intel Core i5 - 4590 3.3 GHz quadcore Processor
GPU: Gigabyte GeForce GTX 1060 G1 3GB
Memory: G.Skill - Ripjaws Series 8GB DDR3 - 1600 Memory
Power Supply: EVGA -SuperNOVA NEX 750W 80+
Motherboard: Gigabyte - GA-H97M-D3H Micro ATX LGA1150 Motherboard
I thought those were the only things that could affect it so I didn't want to put literally everything in it. I hope someone can help me out!
Below is my HWMonitor CPUID Report. Now...I have no idea what it means. If anyone can make sense of these numbers, words, etc. Please let me know. I have no idea. I am putting my life in the hands of people more intelligent than I. Thank you very much for anyone who can help me.
___THIS REPORT IS ME BEING IDLE ON WOW IN DALARAN (place with the most amount of players)___
CPUID HWMonitor Report
Binaries
HWMonitor version 1.3.5.0
Monitoring
Mainboard Model H97M-D3H (0x000001F1 - 0x00A6E5F6)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8620
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8620
LPCIO Revision ID 0x4
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 86 20 04 00 00 00 37 00 00 00 80 40 80 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 30 02 30 00 00 00 00 00 00 00 00 00 00 00 00
70 09 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A30
Hardware Monitors
Hardware monitor ITE IT8620
Voltage 0 0.79 Volts [0x42] (CPU VCORE)
Voltage 1 2.05 Volts [0xAB] (VIN1)
Voltage 2 2.02 Volts [0xA8] (VIN2)
Voltage 3 2.04 Volts [0xAA] (VIN3)
Voltage 5 1.74 Volts [0x91] (VIN5)
Voltage 6 1.54 Volts [0x80] (VIN6)
Voltage 7 1.69 Volts [0x8D] (VIN7)
Temperature 0 31 degC (87 degF) [0x1F] (TMPIN0)
Temperature 2 88 degC (190 degF) [0x58] (TMPIN2)
Fan 0 1957 RPM [0x159] (CPU)
Fan 1 805 RPM [0x347] (FANIN1)
Fan 2 847 RPM [0x31D] (FANIN2)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 19 10 11 00 FF FF 00 00 00 80 60 00 30 58 47 1D
10 FE FF FF 77 C7 82 80 80 01 03 03 FF FF FF FF FF
20 00 AB A8 AA 00 91 80 8D 82 1F 80 58 1F 24 2D CE
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 40 AD 6A D4 00 00 00 00 00
50 FF C8 7F 7F 7F 40 00 00 90 5C 3B 12 65 00 00 00
60 00 14 41 46 1C 03 00 00 00 14 32 46 1C 03 00 FF
70 00 14 32 46 1C 03 00 3E 00 14 32 46 1C 03 00 C0
80 FF FF FF FF FF FF FF FF 02 30 01 02 01 B0 E0 09
90 FF 00 00 00 FF 00 00 00 40 97 00 00 40 B6 C1 BF
A0 00 00 78 00 00 0A 0F 80 7F 7F 7F 80 00 00 0F 80
B0 FC 46 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor ACPI
Temperature 0 28 degC (82 degF) [0xBC2] (TZ00)
Temperature 1 30 degC (85 degF) [0xBD6] (TZ01)
Hardware monitor Display API
Hardware monitor NVIDIA NVAPI
Voltage 0 0.81 Volts [0x32C] (GPU)
Power 0 16.09 pc (GPU)
Temperature 0 48 degC (118 degF) [0x30] (GPU)
Fan 0 0 RPM [0x0] (GPU)
Fan PWM 0 0 pc [0x0] (FANPWMIN0)
Clock Speed 0 1594.50 MHz [0x63A] (Graphics)
Clock Speed 1 4006.80 MHz [0x63A] (Memory)
Hardware monitor Intel I/O
Temperature 0 93 degC (199 degF) [0x5D] (GPU)
Clock Speed 0 598.57 MHz [0x256] (Graphics)
Processors
Number of sockets 1
Number of threads 4
APICs
Socket 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 1 2
-- Core 2
-- Thread 2 4
-- Core 3
-- Thread 3 6
Timers
ACPI timer 3.580 MHz
Perf timer 3.215 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core i5 4590
Codename Haswell
Specification Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 84.0 Watts
Tjmax 100.0 °C
Core Speed 798.1 MHz
Multiplier x Bus Speed 8.0 x 99.8 MHz
Base frequency (cores) 99.8 MHz
Base frequency (ext.) 99.8 MHz
Stock frequency 3300 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
Microcode Revision 0x1E
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 6 MB, 16 thread(s)
FID/VID Control yes
IBRS not supported
IBPB not supported
STIBP not supported
RDCL_NO no
IBRS_ALL not supported
Turbo Mode supported, enabled
Max non-turbo ratio 33x
Max turbo ratio 37x
Max efficiency ratio 8x
O/C bins none
Ratio 1 core 37x
Ratio 2 cores 37x
Ratio 3 cores 36x
Ratio 4 cores 35x
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
TDP Level 84.0 W @ 33x
Temperature 0 96 degC (204 degF) (Package)
Temperature 1 92 degC (197 degF) (Core #0)
Temperature 2 93 degC (199 degF) (Core #1)
Temperature 3 94 degC (201 degF) (Core #2)
Temperature 4 92 degC (197 degF) (Core #3)
Voltage 0 +0.00 Volts (IA Offset)
Voltage 1 +0.00 Volts (GT Offset)
Voltage 2 +0.00 Volts (LLC/Ring Offset)
Voltage 3 +0.00 Volts (System Agent Offset)
Voltage 4 0.97 Volts (VID #0)
Voltage 5 0.97 Volts (VID #1)
Voltage 6 0.79 Volts (VID #2)
Voltage 7 0.97 Volts (VID #3)
Power 00 15.89 W (Package)
Power 01 6.46 W (IA Cores)
Power 02 0.01 W (GT)
Power 03 7.86 W (Uncore)
Power 04 1.56 W (DRAM)
Clock Speed 0 798.10 MHz (Core #0)
Clock Speed 1 798.10 MHz (Core #1)
Clock Speed 2 3491.67 MHz (Core #2)
Clock Speed 3 798.10 MHz (Core #3)
Core 0 max ratio 37.0 (effective 37.0)
Core 1 max ratio 37.0 (effective 37.0)
Core 2 max ratio 37.0 (effective 37.0)
Core 3 max ratio 37.0 (effective 37.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306C3 0x00100800 0x7FFAFBFF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B6FF 0x00000000 0x00C10000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x02C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00042120
0x00000006 0x00000077 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x000027AB 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300803 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x0000000D 0x00000001 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000021 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x35692029 0x3935342D 0x50432030 0x20402055
0x80000004 0x30332E33 0x007A4847 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003027 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00080838 0xF3012100
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040004
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x23242525
MSR 0x00000194 0x00000000 0x00010000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x880003E3
MSR 0x000001FC 0x00000000 0x0000005F
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00000000 0x00001F40
MSR 0x00000610 0x0000FFD0 0x0000EA82
MSR 0x00000611 0x00000000 0x89E4E9FF
MSR 0x00000639 0x00000000 0x44298F62
MSR 0x00000641 0x00000000 0x0000501D
MSR 0x00000619 0x00000000 0x0C088158
MSR 0x00000614 0x00000000 0x000002A0
MSR 0x00000648 0x00000000 0x00000021
MSR 0x00000649 0x00000000 0x00000000
MSR 0x0000064A 0x00000000 0x00000000
MSR 0x0000064B 0x00000000 0x80000000
MSR 0x0000019C 0x00000000 0x880102A2
MSR 0x000001A2 0x00000000 0x00641400
MSR 0x00000198 0x00001995 0x00001400
MSR 0x00000199 0x00000000 0x00002500
CPU Thread 1
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x000306C3 0x02100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000002
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x00000611 0x00000000 0x89E502D8
MSR 0x00000639 0x00000000 0x4429A027
MSR 0x00000619 0x00000000 0x0C08831B
MSR 0x00000198 0x00001A06 0x00001500
CPU Thread 2
APIC ID 4
Topology Processor ID 0, Core ID 4, Thread ID 0
CPUID
0x00000001 0x000306C3 0x04100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x89E51876
MSR 0x00000639 0x00000000 0x4429AE3F
MSR 0x00000619 0x00000000 0x0C0884A8
MSR 0x00000198 0x00001A60 0x00001600
CPU Thread 3
APIC ID 6
Topology Processor ID 0, Core ID 6, Thread ID 0
CPUID
0x00000001 0x000306C3 0x06100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000006
MSR 0x00000611 0x00000000 0x89E52F1F
MSR 0x00000639 0x00000000 0x4429BD85
MSR 0x00000619 0x00000000 0x0C088628
MSR 0x0000019C 0x00000000 0x880402A2
MSR 0x00000198 0x00001A07 0x00001500
Storage
Drive 0
Name WDC WD10EZEX-00BN5A0
Revision 01.01A01
Serial WD-WCC3F2VFL3R6
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 7200 RPM
Features SMART
Volume c:\, 930.3 GBytes (67.0 percent available)
USB Devices
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x0C45, product=0x7605
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x1BCF, product=0x0005
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8009
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8001
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
API Intel I/O
Display Adapters
Display adapter 0
ID 0x1090306
Name NVIDIA GeForce GTX 1060 3GB
Board Manufacturer GIGABYTE Technology
Revision A1
Codename GP106
Technology 16 nm
Memory size 3 GB
Memory type GDDR5
PCI device bus 5 (0x5), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1458)
Model ID 0x1C02 (0x373A)
Revision ID 0xA1
Performance Level 0
Core clock 1594.5 MHz
Memory clock 4006.8 MHz
Display adapter 1
ID 0x4400000
Name Intel(R) HD Graphics 4600
Technology 22 nm
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x1458)
Model ID 0x0412 (0xD000)
Revision ID 0x6
Performance Level 0
Core clock 598.6 MHz
Monitor 0
Model VX228 ()
ID ACI22C1
Serial F9LMRS002325
Manufacturing Date Week 36, Year 2015
Size 21.7 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-83 kHz
Vertical Freq. Range 56-75 Hz
Max Pixel Clock 150 MHz
Gamma Factor 2.2
Binaries
Monitoring
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8620
Config Mode LDN 0x4
Hardware Monitors
Processors
Number of sockets 1
Number of threads 4
APICs
Socket 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 1 2
-- Core 2
-- Thread 2 4
-- Core 3
-- Thread 3 6
Timers
Sys timer 1.000 KHz
Socket 1 ID = 0
Codename Haswell
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
Tjmax 100.0 °C
FID/VID Control yes
IBRS not supported
IBPB not supported
STIBP not supported
RDCL_NO no
Max turbo ratio 37x
O/C bins none
Ratio 1 core 37x
Ratio 2 cores 37x
Ratio 3 cores 36x
Ratio 4 cores 35x
Thread dumps
CPU Thread 0
APIC ID 0
CPUID
CPU Thread 1
APIC ID 2
CPUID
CPU Thread 2
APIC ID 4
CPUID
CPU Thread 3
APIC ID 6
CPUID
Storage
Drive 0
Revision 01.01A01
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Features SMART
USB Devices
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
API Intel I/O
Display Adapters
Display adapter 0
ID 0x1090306
Revision A1
Codename GP106
Technology 16 nm
Memory size 3 GB
Memory type GDDR5
Revision ID 0xA1
Performance Level 0
Display adapter 1
ID 0x4400000
Technology 22 nm
Revision ID 0x6
Performance Level 0
Monitor 0
Model VX228 ()
ID ACI22C1
Serial F9LMRS002325
Size 21.7 inches
Gamma Factor 2.2
