There's some slight discoloration on my cpu, it's slightly darker than the rest of the golden surface but it's hard to see in the pictures; my computer will not boot up at all. The problem may not be my cpu, however.
My problem started when I completely misused a can of air; I shot out air that was too cold and it probably damaged at least one part of the computer, if not others. It booted up after I put it back together after the cleaning, but then shorted out and just turned off with no screen after 1 minute of being on. It has not turned on ever since.
We've tried a different PSU. We were going to try a new motherboard when we noticed the discoloration on the CPU. There was also some dust that had blow around into the sides of the cpu, as well a broken pin.
Main question - is the spot on the cpu bad? I know the pin would be the most obvious answer, but whatever damage I did with the compressed air couldn't be connected to the pin, and things were running perfectly fine before the compressed air incident.
So is my problem the CPU? Could I damage a new motherboard when using this CPU? What else could the problem be?
Thanks for any help.
